I'm trying to open .dgm file in creo parametric 2.0.
It is showing me an error "This functionality requires one of: DIAGRAM".
How can I open this file in Creo?
Accroding to https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS111228&art_lang=en
Resolution | License for Pro/DIAGRAM module is required to open or create new diagram file |
Chanveer,
As Deven mentioned you needs Diagram licenses to open DGm files, DGM files are diagram files. This license needs to create new diagram files as well.
