In using Creo Illustrate with PTC Creo View Files Tools for publishing, The "PVZ" output file doesn't allow watermarks to be published. We have Windchill / model security labels "ATTRIBUTES/PARAMETERS" that don't publish.
I created our watermarks ini files using the old "ProductView Watermark Editor", The ini files work for Creo View and Creo Illustrate independently. The only impact is generating a Creo Illustrate generated pvz the watermarks are not visible in our files. We would like the watermarks to be published using our output of Creo Illustrate. We have our Windchill lifecycle designs, security labels that we would like to preserve on our Figures and screen sequences .
