does anyone know how to re-activate a c3di file after a crash of CreoIllustrate 1.0?
I had deleted a small animation from a figure and I had already a few times the error message from Windows7-64 bit as shown in the attached screenshot creo_absturz_sml.jpg.
Today I had a similar situation in an c3di-Illustration with about 6 or 7 figures, when I had deleted a 50 sec approx. animation from a figure and then wanted to save the illustration.
When I now want to reopen the illustration, creoIllustrate states the error message shown in the scond attached screenshot. Is there a log or a backuptool installed with creoIllustrate which might help to use the file again? Otherwise, a lot of work would be lost to Nirvana....
The text from the error message says, the illustration might be used by someone else...? But I just restarted the computer and the first action was to start CreoIllustrate and to try opening the file, so...
Hello!
1. Do you removed the Galaxy program which may stay installed after beta testing of Arbortext Galaxy Beta? Remove this program (and folder in "Program Files" if it remains).
2. What service release of Creo Illustrate are you using?
3. Can you attach your "c3di" file to the message?
Hello Vladimir,
I will attach two files for the information you asked for, but unfortunately I cannot send you the c3di-file.
There is no Galaxy program installed on this machine as far as I can see. But I found the galaxy files in creo illustrate and creo view as plugin. Should I delete those files? Or remove the plugin (but how?)
Our company has been scheduled to get the CreoIllustrate 2.0, but until now I cannot find it in our download area, and Regine Mülle is after that.
Regards from Bremen
--ppo
Peter,
Peter Podlich wrote:
...I will attach two files for the information you asked for, but unfortunately I cannot send you the c3di-file.
Ok. You use Creo Illustrate 1.0 M030 - the latest service release for version 1.0.
...There is no Galaxy program installed on this machine as far as I can see. But I found the galaxy files in creo illustrate and creo view as plugin. Should I delete those files? Or remove the plugin (but how?)...
Of course not. Arbortext Galaxy - it was a separate application.
...Our company has been scheduled to get the CreoIllustrate 2.0, but until now I cannot find it in our download area...
I have the same issue. It's strange, because release of Creo Illustrate 2.0 F000 was on March 14.
Note that in Creo Illustrate 2.0 available tools for recovering lost files after crash or premature exit.
There are functionality enhancements in this area in Creo Illustrate 2.0
Creo Illustrate now periodically saves your illustration as you make changes. You can see messages about theseautomatic saves in the Messages pane on the lower panel.
If Creo Illustrate exits prematurely before you save changes, the Recover Files dialog box opens when you restartthe application. Options for recovering files are listed below:
Peter,
There is a 'lock' put on each c3di file as it is opened in Creo Illustrate to prevent 2 illustrators working on the same file at the same time. The lock is taken off when you close the illustration, but it would appear that your crash has left the lock in place.
I think the easiest solution for you is to manually copy the c3di file (copy, not move) the file and give it a new name. You should now be able to load the new file into Creo Illustrate.
Creo Illustrate 2.0 handles this type of situation more robustly and graciously.
Tim
Thanks Tim. I have opened a case that Peter get the access to Creo Illustrate 2.0.
Best regards,
Regine
Thank you Tim, I tried it three or four times, copied the crashed file to another partition and into new names, but the 'lock' seems to be not only set, but even blocked or destroyed.
Opening the copied, renamed files produces the same error msg as in the original file.
Yesterday, I did a redo of my work from the import file and so I do not really need the crashed file reanimated;-)
I'm looking forward to working with the new version 2.0.
I realized, that version 1.0 easily crashes on my machine, when I delete animations from a figure and continue working, although the sign keeps on turning in the right upper corner next to the help symbol. Nevertheless I could even export animations to wmv, while in this program state. But I could not exit form creo illustrate without the crash message at the end - so no 'save' was possible.
Hope, that information might be useful for further investigation.
--ppo
I recommend to you to create a new "Case" and describe your issue with Creo Illustrate for PTC's technical support, here: "Log a New Case".
