What is the best way to add contacts to unused ports. I am able to run a terminator table to assign contacts to ports with conductors attached, and then run a customized pin table on the connector to assign contact information with the pins used for conductors removed. Any quicker more automated method?
jef
CreoSchematic1 & WF4
Michael, Peter,
Thanks for the help. I figured out my mistake. I use a parameter “cma” in spools, and that is what defines the min/max wire size in the terminator table. It is a real number and I just set to “0”. Should have been an “*”.
jef
