Clamp simulation with contact
gfraulini
17-Peridot
Hi folks,
here the little simplified assembly in creo 8.0.9.
I tried to simulate with Simulate the effect over a stator of a clamp.
The program gives to me always the error "Creo Simulate could not generate elements for all of the
entities in the model"
I've just tried to mesh the single parts and it works. The problem is only in the assembly with the part of the stator. I tried also:
  • without the symmetry
  • with different fixing
  • fixing all the dof for better numerical stability
  • without contact interface
I don't know where I'm going wrong.
Proposal attached
gfraulini
17-Peridot
(To:skunks)
It seems that the problem is the Mesh option "prismatic" over the stator part. How can I control the prismatic elements dimensions? The normal controls to di this operation see don't work.
Would you like to do this?
This works if you delete all AGEM controls. You are asking for pretty small elements.
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Andra
