Hi, I'm trying to create some Force & Moment diagrams for a simply supported beam, with a pin support on the left side and a roller support on the right side, and some distributed and point loads.
The problem is that I can't find the option to make these diagrams.
I've read several tutorials that said to do this, open the Results Window Definition, select the Graph Display Type, and select Force & Moment under Quantity.
However, there is no such option in my software. I'm using Creo Simulate 3.0 M080
I'm not sure what fixed the issue, but I constructed the beam from a line this time and used point datums as reference points for forces instead of manually creating lines for the purpose.
