Here, some problem on creo simulate. there's any thing displayed on status after running, but complete messages pop up on diagnosis. Problem is, anything computied or anaylized. So, i can't review them.
Several times worked, but now it is not worked in same method.
Is there any bug?Could you provide any solution??Do you help me~~?
Thanks.
