Creo 2.0
I have a large solid of an assembly. Certain areas need to be colored for identification. I cannot get to all the surfaces because by turning the model other parts of the solid block my view. Is there a way to get in close enough that other parts won't interfere with what I am seeing. These are not separate parts so I cannot open them into a new window by themselves. In my native program Catia I can switch between perspective and parallel. Parallel is what the general viewer in Creo acts like. Perspective allows one to get in close without interference from other parts. Kind of like a flythrough function. Is there a function inCreo that allows for this? Will it work in the render tool?
So if I am understanding correctly, you want to select something behind another item or surface?
For surface selection, change the selection filter in the bottom LH corner to geometry, then put the mouse over the area where the surface is that you want to select and right mouse button click until the surface you want highlights. You can also RMB click and hold and in the RMB popup, select "pick from list" to get a listing of surface in the area of the mouse pointer.
I may be way off base from what you are asking that this makes no sense, if so, please feel free to roll up a newspaper and hit me on the head with it!!!!
in your model tree, select the offending model(s) (multiple select, hold down the ctrl key)
RMB > hide
to restore
RMB > unhide
It's multiple parts in a dumb solid, an IGES. If I hide the offending parts I also hide what I am working on. But I still need to color individual parts on that solid using surface rendering. I just colored what could be seen because what cannot be seen, won't be seen for the same reason I have the issue for my project.
Hi Richard, did you check to see if the parts are on levels?
