I have a family table with different instances that are made up of different key design features. Originally we sent out one of these instances to be molded. At this point this instance was at A.1, now after some consideration we have made some minor changes for later on but want to stick with the initial A.1 design. My issue is that I need to modify the drawing from this A.1 iteration to add something but it is updated to the newest A.4 iteration. I am unsure how to go about doing that. I am able to see the entire history of the model on windchill but I get an error when I try to open it locally.
Conflict Management
You will never be able to modify A.1 and keep it A.1!!!
Every time you check in a file to Windchill, the iteration (Y in x.Y) increases.
It looks like someone else has checked in your part 3 times since you last did, thus A.4 in Windchill common space, but you still have A.1 in your workspace.
The only resolution is a) a new part number or b) update your workspace to the latest iteration and make your mods from there.
Can you promote A.1 to A.5?
