Keep creo simulation results window open
ErikClacey
One thing that has annoyed me for many years now is that when I perform a simulation using Creo simulate within Creo, I can open the simulation results window, but I have to close that window in order to continue working in Creo. Is there a specific reason why? Is there maybe a configuration/setting that allows this "function"? Often when for example doing a static load analysis I'd like to keep the Simulation results window open to consult it on changes that I have to make before simulating it again.
I save the color plot as Creo View (example attached).
ErikClacey
(To:skunks)
Thanks to the workaround. However, it would have been nice to have something that is not a workaround, so I added this as a product idea. If you agree, I hope you'll upvote it to increase the awareness., Link: Product idea
