I have problem with Creo 3.0. When I run Creo, it shows a warning message wich says:
License request failed for feature
Invalid feature name: [FEATURE NAME]
Next I click "OK" and the application shuts down.
I found similar topics on this support, but the advice in this topic doesn't work:
(Creo 3 - Invalid feature name)
Do you have some tips for my problem?
Raffael,
Are you using Commercial or student edition of Creo?
@mahesh sharma
I'm using the student version, but i got it fixed already.
Before i was using the new Creo 3.0 M130 version (the newest i had atleast) which gave me that error, but now i tried installing it with an older installation version and it worked!
But thanks anyways!
Raffael,
Good to know that Creo is working now. You may mark your reply as correct answer for the post.
I guess that the root of the problem is missing parametric.psf file in Creo installation.
<Creo3_LOADPOINT>\Creo 3.0\Mxxx\Parametric\bin\parametric.psf
MH
