On the function of the sweep's tangent tab
ykimura
8-Gravel
Hello everyone
I will write for the first time.
I am not good at English, so I am sorry if there is a strange expression.
In the sweep command, there is a tangent tab, but I did not understand exactly what role it would play for this function.
If there are easy-to-understand illustrations and samples, would you please teach me?
I am sorry to trouble you, but thank you for your consideration.
ykimura
8-Gravel
(To:mbonka)
Hello mbonka
Thank you for your help.
I was able to grasp about "tangent" in general by referring to the items from the movie that I received and PTCU.
Thank you very much.
mbonka
(To:ykimura)
Hello @ykimura
 welcome to PTC community. Try to search on youtube, there can be some usefull video tutorials.
https://www.youtube.com/results?search_query=creo+parametric+swept+blend
ykimura
8-Gravel
(To:mbonka)
thank you very much.
I will check the movie you taught and check it immediately.
mbonka
(To:ykimura)
l´m not able to describe your question "in words"... some video can be better.
Hope it will helps
ykimura
8-Gravel
(To:mbonka)
Hello mbonka
Patriot_1776
(To:ykimura)
Keep in mind also that there are 2 different directions for "tangent", as there are for "normal".  Depending on the boundary and what it picks, you could get some wonky results.
Hello FrankSSchiavone
Thank you for the supplementary information.
I'd like to check various patterns and change the pattern.
