Relation to identify parameter type
Ketan_Lalcheta
I would like to know how to check type of parameter from relation. For example, TOLVAL is parameter present into model. This I can check using exists function in relation. Could you please somebody help me know how to identify type of this TOLVAL parameter using relation.
Thanks in advance!
Ketan
0 REPLIES 0
