I am wondering if Creo has any functions can help to check sketch validity. Sketch validity means that there is no self-intersection, no gaps, and so on. In CATIA, it has this function.
Hello
Yes, in the sketch you can see if the construction is good.
Closed, no double respect.
Kind regards.
Denis.
A closed boundary in the sketch will add a transparent hue to the enclosed boundary.
By default, Creo sketches self-dimensions and self-constrains.
If you see gray dimension and/or constraints, these are not locked in.
Also some tips below this button in the sketch ribbon:
