I would like to know how to use this function. I cant find much instruction on it. All the other selections for Style do their thing but when I select the "Activate Display Style" I get the error message about no common user-defined state found. I'm not even sure this function will do anything I need but I'd like to figure out how to use it.
Hi Ken,
You can find some additional information in the Help Center under:
Creo Parametric > Assembly Design > Creo Parametric Assembly > Using Assembly > Managing Views > Assembly Display Style
You can take a look at the following documents:
About Display Style for an Assembly
To Redefine a Display Style from the Model Tree
I hope this helps.
Amit
