"Density unassigned. Cannot calculate mass props for XXXX.ASM"
cfly
Hello, All:
I have an assembly that won't regenerate to green because it says one of the
subassemblies, which has no geometry, doesn't have a density assigned to it.
Not realizing at first that it was an assembly, I tried assigning a material
to it and it never took; when I realized *that* problem, I tried creating an
empty part, with a material assigned to it, and assembling it into the
assembly in question; still got the same warning when trying to regenerate
the top level.
Creo 2.0/Windchill 10
Thanks in advance for any help!
--Carol
efefefefefefef
Applied Research Labs
University of Texas at Austin
Carol Fly
Mechanical Designer
(512) 835-3397
Fax (512) 835-3259
efefefefefefef
0 REPLIES 0
