A new season of the Arbortext TC Dojo is in the works. What do you want to learn?
No ratings
We're going to start Arbortext TC Dojo sessions again. In the TC Dojo, you tell us what you want to learn and we go find experts to teach it.
This survey is primarily aimed at the needs of Arbortext users, an important segment of the larger technical communications community we serve.
We change the survey questions regularly in response to suggestions we receive from survey takers. You can take it more than once. We want it to reflect your needs as they change over time. Answer it as many times as you want. Let us know what products are most important and what topics you most want to learn.
Take the survey: http://survey.arbortextuser.org
Episode Guide and where to find past sessions
How-to Videos About Arbortext - Arbortext TC Dojo Series Title and Episode Guide
‎May 16, 2017 04:08 AM
