Can we use Style sheet and publishing engine version 6.0 M140 for Arbortext Editor version 6.0M080?
Thank you,
Rajesh
Yes you should be able to go up but not down. We use Arbortext Editor 6.0M80 connected to PE running 6.1m80. You cannot go backwards that is AT6.1 to AT PE 6.0.
