Currently using ISODraw CADprocess 7.4.0.0, There is no options to UNDO or REDO.
Can you please help to get resolve this issue.
Install 7.4.1.0, this issue is resolved in this version. But I see that 7.4.2.0 is now release so I would go to that reversion.
SPR Description
14316065 Fixed behavior of the "undo delete" command
14536641 Fixed EPS file header to make it recognizable for 3rd party applications
14473454 Resolved precision flaw leading to inaccurate rectangular 3D cuts
Bryon
