Dear User ,
Please share your expertise while designing a Cover Page with Styler . I have attached a template for better understanding.
The Coverpage should contains Header , Footer and the CenterContentPage. In the content page the need is to show 3 graphics in 3 different positions.
1. How to position all the 3 graphics in the content region.
2. Is the best practice to design this requirement via Styler or to use image editing tool and just insert it as image.
PLs advise
Sriram Rammohan
Have you considered using a 2 column / 2 row table?
__________________________________
Image 1 |
__ Image 3
Image 2 |
___________________________________
The second column spans 2 rows.
Also borders and frames are turned off.
Image 1 |
__ Image 3
Image 2 |
Thanks Tim for the solution.
Can you also pls check if my solution holds goods , My thought was to create a page region for each components in the Cover Page. In this case Page Region for Img1 ,2 and 3.
Pls point out if I am wrong.
BR,
Sriram Rammohan
Using regions too is a good option.
