Has anyone else encountered a Publish to PDF File failed..due to Dimension too large error?
Trying to isolate the cause.
Tracey
How big would you expect your output to be? I have published pdf files in excess of 20Mb...but nothing really much larger than that.
The documents can get quite big... more well into the gigs, but that was not the issue.
I found the problem. It was to do with pulling content via xpath into a gentext table.
I tweaked it a bit and have managed to get the required output ... just needed to do it a smarter way
Tracey
