Hi Kate, there could be several reasons for the behavior of the callouts that you experienced. The text could be set to white, what would "eleminate" the text. You can double check this by toggling the preview by pressing Ctrl+k. If the text shows up and and the circle is displayed in green, altering the color settings will fix your challenge. If you set an endpoint on the leader line and it will not display, you may edit the line style and put the endpoint / dot on the other end. I keep my fingers crossed that this helps. regards, Christian
