Hello there,
I was wondering if any of you could help me with this.
I have a DITA file named DITA file A (topic file/ map file) which references DITA file B.
Now, I have to make a change in the referenced file DITA file B, but I'm not sure if this DITA file B is referenced by other files or not.
If I change the DITA file B, I think it will also change the DITA files which reference this DITA file B.
Is there any way to find out if the referenced DITA file B is also used by other files?
Thank you very much in advance.
Tomomi
This tends to be a function of the Content Management System. For example in Arbortext Content Manager you can perform a "where used" query to solve the problem you are facing.
If you only have files on a filesystem then it may be easiest to do a "grep" type search over the files.
Cheers,
Gareth
Cheers,
Gareth
