How to change the 'Highlights' position ?
fabien_be
3-Newcomer
Hi All,
I'm working on the customization of a stylesheet. When I try to publish my CMM, I find that the highlights position is after the title page. Which attribute in the FOSI I must modify to make sure that the highlights appear before the title page?
For your information, SGML tag concerned is transltr, the first element in mfmatr.
If you can show some FOSI examples, it will help a lot !
Thank you in advance.
RayStachowiak
(To:fabien_be)
It would be good to know what DTD you are using. I looked in 40051 and the tags were not there. Usually the FOSI is set up based on how the DTD is structured. usually the title page is based on the main document tag, and then other sections follow. Moving the Front matter could involve a bit of work and some skill at using writing FOSI code. I have done it but it depends on how structured you FOSI is and what dependencies there are. It is hard to determine how easy it might be.without seeing the DTD and the FOSI that goes with it.
