Impossible to upload stylesheet with Arbortext Editor 5.3 (old version)
amariani
I get an error message when I try to open a file linked to a stylesheet. It says the stylesheet has been created with a previous version of Styler and it cannot be used unless the stylesheet is upgraded. I read how to upgrade it, but I'd like to be sure this is the right thing to do. Both Arbortext Editor and Styler versions are 3.5. I don't understand where this problem comes from, since nobody modified this stylesheet on purpose (but its properties indicate it's just been modified). I simply set the right addresses in the system registry to locate the dtds, that's all. Please, does anyone know how this operation might have caused this problem? Thanks, Sonia
I've solved my problem by replacing the damaged file with its backup file (.bak). Still I cannot explain how this problem generated. If you have any idea about it, in order to prevent it to happen again, you're welcome anyway.
