Is it possible to customize DITA views in Arbortext Editor (6.1) to have simultaneously bookmap structure and topics content ?
elebreton
3-Visitor
Currently, a DITA Map is basically shown like this, on the left: dita bookmap structure and on the right: the content (but only dita bookmap content and a link for topic).
With the resolved view for edition, we can have the content of topics, but we loose the dita bookmap hierarchical structure (and its content):
I would like to have in the same view (green blocks in the preceding illustrations), the dita bookmap structure on the left and the dita topic content resolved (for editing) on the right.  Is that possible () ?
If you place your cursor in the left hand pane, the you can use ctrl+shift+1, ctrl+shift+2, etc. to display the level of hierarchy that you would like.
However, there is not a method for seeing hierarchy of the unflattened document with the flattened document.
Have you tried
  1. Opening Arbortext Editor
  2. Select Edit > Edit Resolved Document > For Editing
  3. If only one window pane displays, then select Window > Left-Right Split
  4. Place the cursor in the left pane
  5. Select View > Column View
Does this give you the desired results?
Hi Tim,
Thank you for your answer.
In fact, I would like to keep the structure of the map in the RDE view (not only a flatten view of the topics) :
  • on the left : the nested hierarchical structure of the bookmap with topciref
  • on the right : the content of the topics for editing
Is it possible ?
Has your question been answered?
If so, could you answer using the Correct Answer button?
