IsoDraw Macro for "Revert"
bgraffmann
If you record a macro in IsoDraw and select the "Revert" command form the File Menu , something  like
Close confirm_no
Open "C:\MyPath\MyFile.iso"
is recorded. Truely this is what happend - the current file was closed and opend again.
If you want to create an IsoDraw macro for your macro library this is probably too specific.
More likely you don't want to load the file recorded, but the actual file when executing the macro.
So you could replace the recorded lines by
Menu "Revert"
which does exactly the same as if you manually select the "Revert" command from the File Menu.
This method has two drawbacks:
  1. It only works on an English Language Version of IsoDraw.
  2. You can't switch off the "Do you really want to lose your changes?" message.
An other approach is to store the path and name of the file before closing and than open the same file:
Define sDoc as String
sDoc = activeDoc.Path
Close confirm_no
Open sDoc
Sounds good…
  • But what if we want to have the warning message?
  • What happens if no file is open or the file is not already changed?
Here is a complete SubMacro for your macro library that handles all this.
(Anyhow - no warranties!)
SubMacro Revert( Boolean bQuiet )
# Implements a substitute for
# MENU "Revert"
# that is language independend
# and can be quiet or not.
If ( exists(activeDoc) ) then
If ( activeDoc.modified = 0 ) then
If ( bQuiet = false )
Message "Document is saved - can not revert."
End If
Else
Define bClear as Boolean
If ( bQuiet = false ) then
bClear = Get Boolean "Do you really want to revert all changes?"
Else
bClear = true
End If
If ( bClear = true ) then
Close confirm_no
Open sDoc
End If
End If
Else
Message "No open document - can not revert."
End If
End If
End SubMacro
Macro Test_Revert
# Do Revert with User Messages:
Run Revert(false)
# Do silent Revert:
Run Revert(true)
End Macro
0 REPLIES 0
