New Callout Creation
ptc-4629779
Hi Every one,
I have Using Isodraw 7.1. I want create new callout style based on my requirement. See below Requirement.
1. Callout numbers are always located in the middle of the callout number line without background color.
2. The maximum clearance between the callout number line and callout number is 2 mm.
Please find attached .png file for your reference.
Try to create your own callout style:
Thanks for your Support, I have created Callout.
No problem.
Vladimir, is there a way to set this new callout as your standard callout in IsoDraw?
Bryon
Hi Bryon,
You can create a template file in which the required callout is present. And then each new file will be created based on this template by using "File" -> "New".
P.S. Comments about custom template here: http://communities.ptc.com/blogs/vpalffy/2011/02/27/illustration-of-chair-in-arbortext-isodraw-cadprocess#comment-2350
