Ok guys,
this one is just wierd.
I am using Arbortext 5.4M70. I am using DTD's and FOSI. I have a document that will not display the opening Subpara1 element tag. To be more precise it won't show any open tags until you select an element, any element and do a generate update. Then all tags appear as expected, Except the Subpara1 tag.
On my preferences, I have full tags and keep tags balanced selected. Any ideas?
Sindy
Hi Sindy--
I ran into something like this once that had me beating my head against the wall. The answer turned out to be that the element in question had a negative first line indent (an outdent, if you will), that was causing the start tag to get pushed off the left edge of the Editor window. Check for that and see if it is true in your case. If so, you should be able to make that indent conditional on print output so it doesn't affect the Editor view.
--Clay
