PE Composition Error.
Alessio
It looks like the stylesheet parameter has not been provided in the composition parameters array: you only specify outputFile please try to specify the stylesheet full path and stylesheet type as well.
That is: the three required parameters to perform batch composition are outputFile, stylesheet, stylesheetType
The first two should be absolute paths, the third should be "style" if using Stylersheets.
Thanks Marchetti. Stylesheet was missing as parameter to function. Error
got resolved.
Thanks & Regards,
Manisha
"Marchetti, Alessio" <->
02/22/2011 04:30 PM
Please respond to
To
cc
Subject
[adepters] - RE: PE Composition Error.
using Stylersheets.
