Bonjour,
Suite à un passage de Epic Version 4.3 --> ArborText version 6.0
Nous rencontrons un problème avec des fichiers contenant des fragments (appel entitée de fichier) en sgml, perte de '<?Pub CX...>' après sauvegarde du fichier englobant.
Y-a-t-il une solution à ce problème pour conserver le contexte ?
Tétière premier fichier :
<!-- Fragment document type declaration subset:
ArborText, Inc., 1988-2011, v.4002
<!DOCTYPE CODE PUBLIC "-//...//DTD ....//FR" [
<!ENTITY chap2 SYSTEM ".....">
texte...... &chap2; ............texte...
Tétière deuxième fichier (chap2) :
<!DOCTYPE CODE PUBLIC "-//...//DTD ....//FR">
<?Pub CX code(...(...(>
Merci de votre aide
Translation ( Even if my english is not that good )
Migrating from Epic v4.3 to AE 6.0
We encounter a problem when referencing file entities : some PI like '<?Pub CX...>' are being deleted in the subfile when saving the main.
Is there any workaround ?
Main file :
Entity file (chap2) :
Thanks for any help
My point :
Does changing writepi to all change anything ?
Have you reviewed the Arbortext Help topics "Context processing instruction" and "APTFRAGCX — Ignoring the context string during e-i-c matching"?
I did test and that doesn't work!
Hi Mickael. Are you still experiencing this issue? If so, could you clarify it a bit in English if possible? You'll find more of your fellow contributors may be able to assist with the proper information. Thanks!
Main file :
Thanks for any help
My point :
