Hello PTC community!
I have more than 3,000 xml documents, each xml document needs to be published in the PDF format. Rather than opening and convert the document the PDF manually, I wonder that there is any way the ArborText can do this automatically (or with Macro). Any help deeply appreciated,
Have a great day!
If you have Arbortext PE configured, this would be very simple to achieve using a "curl" script to make the necessary web service requests to PE. You can also achieve this via Arbortext desktop but must have Styler or Print Composer. In that case you would write a simple ACL script to call the compose commands for all files.
