Is anyone using SVG images in Web or HTML output from Arbortext? A few Preferences can be changed and it will work, but only in IE (not Chrome) from what I can see. Also, it is placing the SVG image in an intelligent graphic viewer so you can zoom in/out, pan, reset. etc. Interesting, but since it is not cross browser it is a fail.
Maybe someone has solved this?
Andy B.
12/30 STATUS:
The System Variable "APTCOPYGRAPHICEXTS=svg"is set on the author's computer and this is working when publishing through Styler. Topics with an SVG image have a SVG image in the resulting HTML.
However, this is not working when publishing through a Publishing Engine, which is how our 20+ writers publish. Working with PTC to investigate further.
Was there any answer to this issue?
Bryon
