With an ACL function, how to add a new entry in the New Document Dialog Box?
dgopois
With an ACL function, how to add a new entry in the New Document Dialog Box (newlist variable)?
With an ACL function, How to test if this entry exists?
David
Hi David--
See the documentation for "set newlist". I think that should get you where you need to go. (To check if a document type is in there, use option("newlist") and search the value for the target doctype.)
--Clay
Hi David--
--Clay
rdiaz
(To:ClayHelberg)
Hey David,
Any further questions or issues with this?  Please let the Community know if you're all set.  Thanks!
dgopois
(To:dgopois)
HI Rafael,
The Clay reply satisfies me.
Thank you to the PTC community for their help.
David
