XSL-FO fo:external-graphic content height attribute not working
SarahPrice
7-Bedrock
I am having an issue with Arbortext Publishing Engine 7.0 M010 using an XSL-FO stylesheet. PE is not reading the fo:external-graphic content height attribute value.
CODE: <fo:external-graphic src="cams.png" content-height="0.50in"/>
It blows the graphic up more that 10 times the size. The only content height I have been able to get to work is a percentage.
Has anyone else experienced this problem? If so what did you do to correct it?
Sarah Price
This code works:
<fo:external-graphic src="cams.png"  content-height="scale-to-fit" height="0.50in"/>
This code works:
