XUI buttons and shortcuts
pzorrilla
Hello everybody!!
Does anybody knows how can I add shortcuts to my XUI buttons? I'm trying
to implement some usability principles in my tool, and I want to provide
access to the user through the keyboard.
Thank you so much for your help and support. Regards!
Paulette Zorrilla
Look at the map command. I think you are talking about enabling keyboard
commands (or shortcuts) like Control-C for copy to your environment. It is
very easy to do. It gets tricky (not technically, but usability-wise) if
you want to "steal" a default keyboard shortcut your users like.
Anyhow, you would map a keyboard command to the same function that the
button calls. You don't actually connect the keyboard command to the button
itself. You do have to take care, depending on how/where you are creating
this button, to be sure you are enabling the keyboard command in the right
window. (And resetting it if it should return to a "normal" behavior after
some act or state change.)
map control-p execute ComposePDFFile;
map control-r packagename::functionname();
map control-alt-h find -t -q "<_touchup>";
map control-alt-k {command1;command2;command3}
etc.
On Thu, Sep 26, 2013 at 10:07 AM, paulette zorrilla <
paulette.zorrilla@oracle.com> wrote:
> Hello everybody!!
> Paulette Zorrilla
Hi Paulette--
You can also use the ampersand (&) to denote accelerator keys for menu items and buttons. For example, if you display the following as a XUI dialog:
<window focus="clickme">
<button id="clickme" label="&amp;Click" me&quot;=">
<script ev:event="DOMActivate" type="text/javascript">Application.alert("Hi");</script>
</button>
<button label="&amp;No," click=" me&quot;=">
<script ev:event="DOMActivate" type="text/javascript">Application.alert("Bye");</script>
</button>
</window>
The user should be able to press Alt+C to activate the "Click Me" button, and Alt+N to activate the "No, click me" button.
--Clay
