I have so many languages xml file which needs to convert to PDF. Do you have any idea that how can I Create the same by using Arbortext editor.
if you are only one user you could get a copy of styler and have the ability to publish with out publishing engine.
Bryon
Hello RK,
Basically, it require an Stylesheet to convert XML to PDF.
If your XML already comply with built-in Doctypes such as DITA, there are already stylesheets come with Arbortext Editor. You can use a print compose license in Arbortext Editor or Publish Engine to convert XML to PDF using the stylesheet.
If your XML comply with customized Doctype, you will need a stylesheet for it. In Arbortext, you can create stylesheet using 1) Styler. 2) XSLT/XSL-FO.3)FOSI.
Extra license for print compose and Publish Engine required.
Hope this helps
Jingjun
Bryon
