Bonjour on n’arrive pas à ouvrir les .DWG avec un Isodraw 7.3 M080 on obtiens le message ci-dessous : UN PROBLEME INCONNU EST SURVENU
Le Pc est sous Windows 10 64 Bits Version 2004
The English translation is:
Hello, we cannot open the .DWGs with an isodraw 7.3 M080, we get the message below: AN UNKNOWN PROBLEM OCCURRED
The PC is under Windows 10 64 Bits Version 2004.
I'd recommend that you file a case with PTC Technical Support for help with the issue.
