Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
I want to know more about using the .zip file update to the custom folder. I want to make it so my users can pull the .zip file and allow it update the custom directories.
There's pretty good documentation on this feature in the help center. Search for "zipped customizations" and you should be able to find everything you need.
You can also check out a blog post I wrote about the subject a while back, which summarizes some of the advantages of distributing zipped customizations:
Read the instructions in the Deployment kit that matches the version you are using. I believe that you can download it from the same page you get the Arbortext updates.
-Andy Andy Esslinger LM Aero - Tech Order Data (817) 279-0442 1 Lockheed Blvd, MZ 4285 (817) 777 3047 Fort Worth, TX 76108-3916 [Title: Integrated Fighter Group]
