CBQL query to check test case vs test run modified dates?
PeteG2024
6-Contributor
Does anyone know how to create a codebeamer report or cbql query which does the following?
For Test Runs in a Test Run tracker, compare the modifiedAt field with the corresponding Test Case modifiedAt field, to generate a report of test runs that are out-of-date (i.e. the test case has been modified more recently than the the test-run, so the test-run may need to be re-run)
Hello @PeteG2024 ,
This is the closest solution I've found:
Hello @PeteG2024 ,
PeteG2024
6-Contributor
(To:EvaBertalan)
Yes I found the same, thanks. I was hoping there might be a Cbql query to do it and just list where TestCase.modifiedAt > TestRun.modifiedAt,  but can't find enough information on those to progress any further.
Survey Now Live!
Codebeamer Community: we're listening.
Add your voice in our short CSAT survey!
