Can project baselines be available as templates?
MT_12158826
Pretty self-explanatory! Though I don't think it's the case, I wanted to ask around if anyone can confirm that project baselines are not able to templates.
Thanks!
@MT_12158826, you are correct. Baselines are used to capture a snapshot of the project at a specific point in time for historical purposes. If you need to create a template from a baseline, you can use the REQIF export of the desired baseline, reimport it as a new project, and make that project available as a template. Please let me know if you would like additional guidance on how to proceed or if you have any further questions.
Brian Kampling | Software / Systems Engineering Consultant - Source Allies
Hi @MT_12158826,
I wanted to see if you got the help you needed. It seems that @BKampling_SAI's reply is a solution.
If so, please mark it as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Catalina
PTC Community Moderator
PTC
Survey Now Live!
Codebeamer Community: we're listening.
Add your voice in our short CSAT survey!
