从Jira导出的reqifz文件中包含了附件,导入后在Tracker Item中只显示附名称,没有附件内容
Codebeamer currently does not import actual attachment content from a ReqIFz package. When a ReqIFz exported from Jira contains attachments, Codebeamer will only display the attachment name, but the file itself is not imported. This is a known product limitation, not an issue with your file.
If you need the real attachment to appear in the Tracker Item, there are only two options today:
Upload the attachments manually After the ReqIF import.
Automate with the REST API: some teams run a small script that reads attachments from the ReqIFz ZIP and uploads them to the corresponding items.
There is no automatic attachment extraction during ReqIFz import in the current Codebeamer version.
If you’d like, I can inspect your ReqIFz ZIP structure and confirm the attachment block looks correct.
Hello @JR_12222956,
It looks like you have a response from a community expert. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
