I have CB 3.1.0.1 integrated with WC 13.2.1 via the DPT integration and from CB I can click on the linked part to see information about it but I don't have the Creo View widget. Am I missing something in the configuration for this to be enabled or perhaps an additional extension to install?
This is controlled by the PreviewConfig.basicPreview setting in the application configuration. When this is set to true you get a limited view of the Windchill data. Setting to false solved the issue. This setting does not appear to be present in Codebeamer 3.2.
"PreviewConfig": {
"basicPreview": true,
"height": 550,
"width": 710
Hi @rattmice
Thank you for your question.
Best regards,
"PreviewConfig": {
"height": 550,
"width": 710
