Hello all,
trying to Word export for test run tracker but get below error:
com.intland.codebeamer.controller.importexport.export.mergefieldword.DocxMergeFieldExporter$ExportAppError: Error inside export application: Exception in thread "main" java.lang.reflect.InvocationTargetException
at com.intland.codebeamer.controller.importexport.export.mergefieldword.DocxJvmExportManager.checkIfAnyExceptionOrError(DocxJvmExportManager.java:197)
at com.intland.codebeamer.controller.importexport.export.mergefieldword.DocxJvmExportManager.checkForErrors(DocxJvmExportManager.java:172)
at com.intland.codebeamer.controller.importexport.export.mergefieldword.DocxJvmExportManager.checkForErrors(DocxJvmExportManager.java:166)
at com.intland.codebeamer.controller.importexport.export.mergefieldword.DocxJvmExportManager.runJvmExportProcess(DocxJvmExportManager.java:149)
at com.intland.codebeamer.controller.importexport.export.mergefieldword.DocxJvmExportManager.lambda$runJvmDocxExport$0(DocxJvmExportManager.java:85)
at com.intland.codebeamer.flow.form.ParallelProcessGuard.execute(ParallelProcessGuard.java:42)
at com.intland.codebeamer.controller.importexport.export.mergefieldword.DocxJvmExportManager.runJvmDocxExport(DocxJvmExportManager.java:80)
at com.intland.codebeamer.controller.importexport.export.job.ExportJob.convertToDocx(ExportJob.java:177)
at com.intland.codebeamer.controller.importexport.export.job.ExportJob.doExecute(ExportJob.java:117)
at com.intland.codebeamer.utils.scheduler.StopWatchJob.execute(StopWatchJob.java:66)
at org.quartz.core.JobRunShell.run(JobRunShell.java:202)
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573)
Found similar topic in knowledge base where suggested solution is:
See below link:
https://www.ptc.com/en/support/article/CS424822?source=search&as=1
I don't know how to identify deleted working sets.
I am not an owner of tracker and only support user in his issue.
Maybe there is also another fix.
Codebeamer version 2.0.0.5
thank you
Hi @MM_10991077
Thank you for your question.
Best regards,
