create/edit Test Case
MM_10991077
Hello all,
we are not able to create or edit Test Cases.
Always get error:
Transaction rolled back because it has been marked as rollback-only
Tried bellow  article CS416551 and didn't help:
Article - CS416551 - Transaction rolled back because it has been marked as rollback-only when modifying a Test Case in Codebeamer (ptc.com)
Interesting is that creation or edit works if "Document Edit View" is active but not in "Table View or Document View".
thank you
alfonso_c
(To:MM_10991077)
Hello @MM_10991077, This behavior seems unexpected and inconsistent, please raise a Support Ticket so that we can analyze it further. In the ticket, please provide:
Thanks in advance
9 REPLIES 9
Hi @MM_10991077,
Thank you for your question!
Also, feel free to add any additional information you think might be relevant.
Thank you for your participation!
Best regards,
Catalina
PTC Community Moderator
Catalina
PTC
alfonso_c
(To:MM_10991077)
Thanks in advance
Hello Alfonso,
thank you for your reply.
Regarding a project template export.
What data will be exported ?
There might be a problem for project owner to share sensible data.
thank you
gkosa
(To:MM_10991077)
Dear @MM_10991077 ,
when you export your project, exclude the "work items", "reports" and "wiki pages".  That way, we receive only the configuration and no data.
See more details on the following page: https://codebeamer.com/cb/wiki/7060303
Alternative solution can be that you export your project and import the same. You can check what data you'll share with us.
Hello Alfonso,
I did export and import to see what data will be shared (as advised by gkosa).
Result is that create and edit test case is possible after import it as a new project.
Does it make sense to send export to you for analysis, anyway?
thank you
But in Original project there is still not possible to create or edit test cases.
alfonso_c
(To:MM_10991077)
Hi @MM_10991077, in this case, you can raise a Support Ticket reporting this latest information (create and edit test case is possible after import it as a new project) instead of attaching the project. Here is a new checklist:
Thanks in advance
Hello Alfonso,
I am sorry for misleading you.
Below article works:
https://www.ptc.com/en/support/article/CS416551?_gl=1*1s25l4r*_gcl_au*MTI4NDcyNjM5LjE3MjA1MDkwNzE.*_ga*MTQ3ODk2NzEyMC4xNjk5OTQ5Mzcw*_ga_7NMP2MSYPM*MTcyNTAxNjMwNS4xOC4xLjE3MjUwMjExNjMuNTUuMC4w
Problem was on my side because I set rights for subfolders only and did not for ".codeBeamer" itself.
Problem is resolved now.
It was my fault.
Sorry again.
Michal.
alfonso_c
(To:MM_10991077)
Hello @MM_10991077 no worries at all, I am glad to know this got sorted out 🎉 Thanks for informing me and marking this thread as resolved 🙂
Survey Now Live!
Codebeamer Community: we're listening.
Add your voice in our short CSAT survey!
