ANGLE BETWEEN CSYS
cspinelli
ANGLE BETWEEN CSYS
hello everyone,
is it possible to show the angle between csys? if i do analysys between csys it shows me only distances...
thanks
Technically, a CSYS is a point with orientation.  It has no references to lock in an angle with.
CSYS are typically talked about in transformation matrices.
