All Versions pick in the workspace context?
davehaigh
11-Garnet
Anyone know if there is a way from the ProE File Open menu to see all versions of files in the local cache?
If you're not in the context of PDMLink you get this menu:
[cid:image003.jpg@01CC6D31.4F7D5260]
But when you look at your workspace the All Versions pick is grayed out.
The thing is, all the versions are there in the cache. I can copy the lid_* files to another directory and run the rename program on them and then pick an older version of a file. Just had to do this yesterday afternoon. Works well but is a bit painful.
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
bfrandsen
6-Contributor
(To:davehaigh)
Only way I can think of is using the Undo/Redo stack in the Event Manager,
but that will roll back other objects and might not have enought saved
undo's.
So Undo, retrieve, backup and Redo should be possible.
I guess the previous versions will get lost if the cache is cleared,
unless that version is needed in the Undo stack. So clearing the Event
Manager and then the cache should remove all previous versions.
Bjarne
"Haigh, David A." <->
07-09-2011 16:42
Please respond to
To
cc
Subject
[proecad] - All Versions pick in the workspace context?
If you’re not in the context of PDMLink you get this menu:
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Livermore, CA 94550
Attachment Links: image003.jpg (8 k) Site Links: View post online View
mailing list online Send new post via email Unsubscribe from this
mailing list Manage your subscription Use of this email content is
governed by the terms of service at:
