Auto Save
danyoder50
Auto Save
How can I set Pro to auto save to the working directory say every 10 minutes. Thank You in advance.
I don't think it is possible Daniel. At least I never heard about this kind of autosave.
http://www.cogras.cz/products_autosave.htm Sip
I have tray to install this program for autosave. but I push on register and after i select the file when i press open proe in closeing and the program is not instaled. What is the problem? Has someoane this problem? Thanks!
When you modify the protk.dat file you must use a lowercase s in the word save. The directions tell you to use C:\AutoSave\i486*****. The only problem with that is when you extract the files to your Root Drive the folder that it creates is Autosave not AutoSave. Have fun and thanks Sip for all the wonderful help.
