Hi there,
I'm doing a project about transmission lines and I need a little help about the analysis...how I know which section is the best for this structure ? Does the Creo has any tool about it ? I was considering using shape factors...
And how I know if the beams will resist ? I thought about Von Mises tension but I see no connection there...
You can see the model below...
Best regards..
