I'm trying to solve an interesting new case today.
Fill in a glass with a certain volume of water. I would like to change the quantity of water easily by parameter: any idea how to create a solid of the water constrained by the glass shape and the desired variable volume?
Behavioral Modeling has this as an example. They usually model and enclosed surface and use an analysis feature of the enclosed volume.
Francesco,
you can implement bisection method using relations. See attached model.
How to test my model:
After first test you can remove the model from the session, open it again, set your own values for the following parameters, regenerate and repeat the test using procedure described above.
MYVOL
MYEPS
Good luck
Martin Hanak
